path: root/configs/dockstar_defconfig
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
