path: root/configs/dms-ba16_defconfig
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_DWC_AHSATA to KconfigTuomas Tynkkynen
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-20configs: Re-syncTom Rini
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
