path: root/configs/dlvision-10g_defconfig
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
