For legacy reasons we were defining the card detect GPIO for all sunxi
boards in each board's defconfig.
There is actually no need for a card-detect check in the SPL code (which
consequently has been removed already), and also in U-Boot proper we
have DM code to query the CD GPIO name from the device tree.
That means we don't have any user of that information left, so can
remove the definitions from the defconfigs.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Samuel Holland <samuel@sholland.org>
Tested-by: Samuel Holland <samuel@sholland.org>
Commit 08574ed339fb ("Convert CONFIG_SYS_MONITOR_LEN to Kconfig") moved
the definition of said config variable from the common sunxi header to
*every board's* defconfig.
This is a platform choice, not board specific, so remove the variable
from there, instead set the one value for all Allwinner boards in
Kconfig.
Acked-by: Jernej Skrabec <jernej.skrabec@gmail.com>
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
When some configuration symbols were converted from header files to
Kconfig, their values were placed into *every* defconfig file.
Since we now have sensible per-SoC defaults defined in Kconfig, those
values are now redundant, and can just be removed.
This affects CONFIG_SPL_STACK, CONFIG_SYS_PBSIZE, CONFIG_SPL_MAX_SIZE,
and CONFIG_SYS_BOOTM_LEN.
CONFIG_SPL_STACK
CONFIG_SYS_PBSIZE
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
CONFIG_SYS_I2C_MVTWSI
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Convert the CONS_INDEX configuration to Kconfig.
Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not
needed anymore.
Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
[Maxime: Added a depends on ARCH_SUNXI to avoid build breakages]
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The Difrnce dit4350 tablet is a tiny tablet with a 4.3" 16:9 480x272 LCD,
A13 SoC, 512M RAM, 4G NAND, solomon systech ssd2532qn6 touchscreen at
i2c1 address 0x48, Memsic MXC622X accelerometer at i2c1 address 0x15 and
rtl8188etv wifi.
The dts file is identical to the one submitted to the upstream kernel.
