path: root/configs/devkit3250_defconfig
2018-04-13net: phy: Don't limit phy addresses by defaultJoe Hershberger
Some boards expect to find more than one phy while other boards are old and need to be limited to a specific phy address. Only limit the phy address for boards that opt in. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-03-13Move CONFIG_PHY_ADDR to KconfigStefan Mavrodiev
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h). Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section. After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted. - ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted. - devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig. After the changes the suspicious defconfigs passes building. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [jagan: rebased on master] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-13spi: Migrate CONFIG_LPC32XX_SSP to KconfigTuomas Tynkkynen
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-13arm: lpc32xx: switch SPL builds to driver modelVladimir Zapolskiy
For NXP LPC32xx boards the change enables SPL_DM option, this allows to use any driver model UART driver in SPL images, hence a restriction on HSUART in SPL image is removed and well as definitions for non-DM NS16550 driver, its DM version is used instead. Because SPL_DM requires malloc(), enable CONFIG_SPL_SYS_MALLOC_SIMPLE for LPC32xx boards. The change adds about 5KB to the resulting SPL image (for devkit3250 board SPL image is increased from 10672 to 15608 bytes). Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-13arm: lpc32xx: switch serial console to driver modelVladimir Zapolskiy
On NXP LPC32xx platform for non-SPL builds the change adds standard (NS16550) and high-speed UARTs to driver model. Due to specific of DM NS16550 device description UART clock can not be got in runtime and by default it is set to 13MHz, if board PERIPH_CLK is different, this should be specified in board configuration file. For SPL builds HSUARTs are disabled and non-DM NS16550 driver is compiled, if needed. The change also updates default configs of devkit3250 and work_92105 boards to reflect updates in platform files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-12lpc32xx: devkit3250: add spl build supportVladimir Zapolskiy
The change adds SPL build support to Timll DevKit3250 board, the generated SPL image can be uploaded over UART5, JTAG or stored on NAND. SPL is designed to load U-boot image from NAND. All new NAND chip defines in board configuration are needed by SPL NAND "simple" framework, the framework is used to reduce potentially duplicated code from LPC32xx SLC NAND driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: update of board configurationVladimir Zapolskiy
This change adds more peripherals to Timll DevKit3250 board, namely MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C. Also the default serial console is changed to UART5, added an option to pass device tree blob by means of bootm, predefined environment variables are slightly extended and reserved space on NAND to store user defined U-boot environment. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
