path: root/configs/devkit3250_defconfig
2016-01-13arm: lpc32xx: switch SPL builds to driver modelVladimir Zapolskiy
For NXP LPC32xx boards the change enables SPL_DM option, this allows to use any driver model UART driver in SPL images, hence a restriction on HSUART in SPL image is removed and well as definitions for non-DM NS16550 driver, its DM version is used instead. Because SPL_DM requires malloc(), enable CONFIG_SPL_SYS_MALLOC_SIMPLE for LPC32xx boards. The change adds about 5KB to the resulting SPL image (for devkit3250 board SPL image is increased from 10672 to 15608 bytes). Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-13arm: lpc32xx: switch serial console to driver modelVladimir Zapolskiy
On NXP LPC32xx platform for non-SPL builds the change adds standard (NS16550) and high-speed UARTs to driver model. Due to specific of DM NS16550 device description UART clock can not be got in runtime and by default it is set to 13MHz, if board PERIPH_CLK is different, this should be specified in board configuration file. For SPL builds HSUARTs are disabled and non-DM NS16550 driver is compiled, if needed. The change also updates default configs of devkit3250 and work_92105 boards to reflect updates in platform files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-12lpc32xx: devkit3250: add spl build supportVladimir Zapolskiy
The change adds SPL build support to Timll DevKit3250 board, the generated SPL image can be uploaded over UART5, JTAG or stored on NAND. SPL is designed to load U-boot image from NAND. All new NAND chip defines in board configuration are needed by SPL NAND "simple" framework, the framework is used to reduce potentially duplicated code from LPC32xx SLC NAND driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: update of board configurationVladimir Zapolskiy
This change adds more peripherals to Timll DevKit3250 board, namely MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C. Also the default serial console is changed to UART5, added an option to pass device tree blob by means of bootm, predefined environment variables are slightly extended and reserved space on NAND to store user defined U-boot environment. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
