path: root/configs/dbau1550_el_defconfig
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-01MIPS: kconfig: add options for dbau1x00 board variant selectDaniel Schwierzeck
The dbau1x00 board can be built with various variants which are configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus add new Kconfig options for those board variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
