path: root/configs/db-mv784mp-gp_defconfig
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Remove SYS_MALLOC_CLEAR_ON_INIT from DB-MV784MP-GP AXP boardStefan Roese
By removing CONFIG_SYS_MALLOC_CLEAR_ON_INIT, the bootup time is a bit faster. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Enable DM_USB on AXP / A38x boardsStefan Roese
This patch enables DM_USB on the Marvell AXP / A38x eval boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-21arm: mvebu: Add DM (driver model) supportStefan Roese
This patch adds driver model support for some Marvell MVEBU SoC's. Including Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now selected automatically for MVEBU platforms. With this DM support now available for MVEBU, hardcoding the base addresses and other information is not necessary any more. Probing should be done by using the values provided via the device tree now instead. For this the driver also need to be converted to DM. Patches for some of the drivers will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-20arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig fileStefan Roese
Introduce a mach-mvebu/Kconfig for all Armada based SoC's. Signed-off-by: Stefan Roese <sr@denx.de>
2015-08-25arm: mvebu: Enable NAND on db-mv784mp-gpStefan Roese
This patch enables NAND support on the Marvell Armada XP DB-MV784MP-GP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Morrow <peter@senient.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-10-23arm: armada-xp: Add basic support for the Marvell DB-MV784MP-GP boardStefan Roese
This patch adds basic support for the Marvell DB-MV784MP-GP evaulation board. This is the first board that uses the recently created Armada XP 78460 SoC support. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
