path: root/configs/db-88f6281-bp-nand_defconfig
2020-07-09db-88f6281-bp-nand: Enable DM_SPI/SPI_FLASHJagan Teki
Enable DM_SPI, DM_SPI_FLASH for db-88f6281-bp-nand board. Cc: Chris Packham <judge.packham@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-15rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOODTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code. Reviewed-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-26ARM: kirkwood: enable CONFIG_DM_USB on db-88f6281-bpChris Packham
Switch to the driver model for USB on the db-88f6281-bp board. CONFIG_BLK can't be enabled yet because mvebu_mmc.c needs converting. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-26ARM: kirkwood: add db-88f6281-bp boardChris Packham
This is Marvell's Kirkwood development board. It has the following features - 512M DDR2 - 2 PCI connectors - 1 x1 PCI-e interface - 1 Gigabit Ethernet Port - 2 SATA Ports - USB 2.0 Interface - SDIO - 128M NAND Flash - 16M SPI Flash It can be strapped to boot from SPI or NAND so there are two defconfigs (one per boot media). Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
