path: root/configs/da850evm_nand_defconfig
2019-06-05ARM: davinci: SPL: fix BSS initializationSekhar Nori
U-Boot README recommends initializing SDRAM in board_init_f(). DA850 was doing it as part of board_init_r() (through call to spl_board_init() which calls arch_cpu_init() which calls da850_ddr_setup()) This worked fine till commit 15b8c7505819 ("davinci: da850evm/omapl138-lcdk: Move BSS to SDRAM because SRAM is full") moved BSS to SDRAM. Functions like mmc_initialize() called in board_init_r() assume BSS is available. Since SDRAM was not initialized when arch/arm/lib/crt0.S tried to initialize BSS to 0, BSS is not initialized correctly. Fix this by simply calling arch_cpu_init() from board_init_f(). Also move preloader_console_init() there to help debug issues with board_init_r(). With this spl_board_init() is no longer needed, we remove it. Tested using MMC/SD boot on OMAP-L138 LCDK board. Tested-by: Adam Ford <aford173@gmail.com> #da850evm Signed-off-by: Sekhar Nori <nsekhar@ti.com> Tested-by: Peter Howard <phoward@gme.net.au> #omapl138_lcdk
2019-04-12ARM: davinci: da850evm: Enable SPL_OF_CONTROL without PLATDATAAdam Ford
With the memory mapping giving us some more avialable RAM, this updates the da850-evm-u-boot.dtsi to include the serial port, SPI and Flash nodes along with some dependent nodes in the SPL dtb. This also removes the platform data initialization code for the serial port and SPI Flash. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-19ARM: da850evm: Increase Malloc SizeAdam Ford
The SPI NOR frameware was recently updated, but they require a little more memory that we had previosly allocated, so it stopped booting. This patch doubles the size of CONFIG_SPL_SYS_MALLOC_F_LEN to 0x800. Fixes: c4e8862308d4 ("mtd: spi: Switch to new SPI NOR framework") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-12Merge git://git.denx.de/u-boot-sunxiTom Rini
[trini: Convert da850evm_nand defconfig now to to SPL_DM] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-29ARM: da850evm: Pinctrl for da850evmAdam Ford
The simple pin controller works for da850, so this patch enables this to pin-mux the pins defined in the device tree for the da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-29ARM: da850evm: Enable CMD_DM for da850evmAdam Ford
With DM enabled, this patch enables the 'dm' command to access the dm tree, uclass and devres. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: configs: Add da850evm_nand to boot from NANDAdam Ford
The DA850-EVM supports booting from NAND when used with the UI expander board. da850evm_nand will create an ais file that can be burned to NAND and booted while storing the env in NAND along with some partitions tables for storing kernel, dtb and rootfs in NAND. Signed-off-by: Adam Ford <aford173@gmail.com>
