path: root/configs/da850evm_direct_nor_defconfig
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
