path: root/configs/da850evm_direct_nor_defconfig
2019-02-19ARM: da850evm: Increase Malloc SizeAdam Ford
The SPI NOR frameware was recently updated, but they require a little more memory that we had previosly allocated, so it stopped booting. This patch doubles the size of CONFIG_SPL_SYS_MALLOC_F_LEN to 0x800. Fixes: c4e8862308d4 ("mtd: spi: Switch to new SPI NOR framework") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-22ARM: da850evm_direct_nor: Remove DM_I2C_COMPATAdam Ford
The da850evm does not need this enabled, so this removes a notice that appears during compile time that says "Please remove" Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-29ARM: da850evm_direct_nor_defconfig: Enable DM_SERIALAdam Ford
With DM enabled, this patch enables DM_SERIAL and removes the NS16550 initialization from da850_lowlevel since the driver will take care of that itself. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-29ARM: da850evm: Pinctrl for da850evmAdam Ford
The simple pin controller works for da850, so this patch enables this to pin-mux the pins defined in the device tree for the da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-29ARM: da850evm: Enable CMD_DM for da850evmAdam Ford
With DM enabled, this patch enables the 'dm' command to access the dm tree, uclass and devres. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-14Revert "ARM: da850evm_direct_nor_defconfig: Enable DM_SERIAL"Tom Rini
This commit is breaking several variants of da850, so: This reverts commit 5f389201dece76b484443773dce2525dc205f5a1. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-11ARM: da850evm_direct_nor_defconfig: Enable DM_SERIALAdam Ford
2018-09-11ARM: da850evm_direct_nor: Enable CONFIG_BLKAdam Ford
At least for now, CONFIG_BLK is working, but this variant of the da850evm doesn't need/support SPL so it's OK to enable it here. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-23Convert CONFIG_DA8XX_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DA8XX_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_SOC_DA8XX et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SOC_DA8XX CONFIG_SOC_DA850 CONFIG_DA850_LOWLEVEL CONFIG_MACH_DAVINCI_DA850_EVM CONFIG_SYS_DA850_PLL_INIT CONFIG_SYS_DA850_DDR_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: David Lechner <david@lechnology.com> [trini: Rework CONFIG_SYS_DA850_PLL_INIT so it's selected on SOC_DA8XX] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-29ARM: da850-evm: Enable DM_I2CAdam Ford
With DM now enabled with the device tree pulled from Linux, we can enable DM_I2C in U-Boot. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add DM_I2C_COMPAT to da850_am18xxevm to fix warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-29arm: da850-evm: Enable DM and device tree support for da850-evmAdam Ford
With the device tree ported and DM compatible drivers, enable: OF_CONTROL, DM_SPI, DM_SPI_FLASH and DM_SERIAL Note: DM_SERIAL is not enabled for da850evm_direct_nor_defconfig yet. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13Convert CONFIG_MAC_ADDR_IN_SPIFLASH et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_ADDR_IN_EEPROM Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12davinci: da850-evm: switch to using TI_COMMON_CMD_OPTIONSAdam Ford
Like the OMAP-L138 LCDK before it, let's move the da850-evm and the variations to TI_COMMON_CMD_OPTIONS to cut back one some of the defconfig entries. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
