path: root/configs/da850evm_defconfig
2020-07-06Merge branch 'next'Tom Rini
Merge all outstanding changes from the current next branch in now that we have released.
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-29spi: Convert CONFIG_DM_SPI* to CONFIG_$(SPL_TPL_)DM_SPI*Lukasz Majewski
This change allows more fine tuning of driver model based SPI support in SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI support in SPL and TPL via Kconfig option. Before this change it was necessary to use: /* SPI Flash Configs */ #if defined(CONFIG_SPL_BUILD) #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH #undef CONFIG_SPI_FLASH_MTD #endif in the ./include/configs/<board>.h, which is error prone and shall be avoided when we strive to switch to Kconfig. The goal of this patch: Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL). Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must still support non DM driver. Another use case is the conversion of non DM/DTS SPI driver to support DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the distinction is needed in Kconfig (also if SPL version of the driver supports OF_PLATDATA). In the end of the day one would have to support following use cases (in single driver file - e.g. mxs_spi.c): - U-Boot proper driver supporting DT/DTS - U-Boot proper driver without DT/DTS support (deprecated) - SPL driver without DT/DTS support - SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to run full blown DT/DTS) - SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained environment with no fitImage and OF_LIBFDT support). Some boards do require SPI support (with DM) in SPL (TPL) and some only have DM_SPI{_FLASH} defined to allow compiling SPL. This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI) and provides corresponding defines in Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [trini: Fixup a few platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-06-26Convert CONFIG_BOOTP_DNS2 to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOOTP_DNS2 CONFIG_BOOTP_PXE_CLIENTARCH Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-09cmd: mdc/mwc: normalize disjoint MX_CYCLIC usageJoel Johnson
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig, but only the non-CMD version currently does anything. This changes all usages to prefer the CMD_MX_CYCLIC option (since it's only affecting addition of the commands), and switches defconfigs using the non-CMD version to use the CMD version. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-05ARM: da850-evm: Disable SYS_MMCSD_RAW_MODE_USE_SECTORAdam Ford
The da850-evm doesn't have the boot pins configured in a way to make MMC/SD booting an option, and MMC/SD support is not enabled in SPL. Therefore, there is no need to support raw mode mmc/sd support in SPL. This patch disables CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR Signed-off-by: Adam Ford <aford173@gmail.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23Convert CONFIG_MX_CYCLIC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MX_CYCLIC Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: David Lechner <david@lechnology.com>
2019-08-08ARM: da850-evm: Enable the USB PHY and MUSB DriverAdam Ford
This patch will enable the MUSB driver to support mass storage devices connected to the OTG port in host mode. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-31ARM: da850-evm: Replace CMD_SF with CMD_MTDAdam Ford
This patch enables MTD and CMD_MTD and it works with SPI NOR, so the older CMD_SF can be removed. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-31ARM: da850evm: Split MTDPARTS into SPL and u-bootAdam Ford
The MTDPARTS currently lists just u-boot.ais as 512k in size. This works when loading the ais file via serial port, but if one wanted to update just the u-boot portion, it's not really possible. This patch splits the MTDPARTS into a 32k SPL partiion and a 480k u-boot partition which allows u-boot.img to be burned to the u-boot partition. The remaining partitions are left with the same sizes and offsets to not break backwards compatibility. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-29davinci: da850-evm: enable driver model for NANDBartosz Golaszewski
Enable the driver-model on da850-evm. We need to add a dummy nand node to the device tree, as the real nand node is a sub-node of the aemif device. On linux the aemif driver populates all its child nodes, but we can't do it in u-boot currently. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
2019-07-27ARM: da850evm: Remove legacy OHCI referencs and unify platformAdam Ford
OHCI was added with DM_USB support, so there are a few unneeded items in the header file that can be removed. This also unifies da850evm with NOR and NAND booting options so all have OHCI support. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate da850_am18xxevm] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-25net: davinci_emac: convert to using the driver modelBartosz Golaszewski
Now that we removed all legacy boards selecting TI_EMAC we can completely convert the driver code to using the driver model. This patch also updates all remaining users of davinci_emac. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Tested-by: Adam Ford <aford173@gmail.com> #am3517-evm & da850-evm Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2019-06-05ARM: davinci: SPL: fix BSS initializationSekhar Nori
U-Boot README recommends initializing SDRAM in board_init_f(). DA850 was doing it as part of board_init_r() (through call to spl_board_init() which calls arch_cpu_init() which calls da850_ddr_setup()) This worked fine till commit 15b8c7505819 ("davinci: da850evm/omapl138-lcdk: Move BSS to SDRAM because SRAM is full") moved BSS to SDRAM. Functions like mmc_initialize() called in board_init_r() assume BSS is available. Since SDRAM was not initialized when arch/arm/lib/crt0.S tried to initialize BSS to 0, BSS is not initialized correctly. Fix this by simply calling arch_cpu_init() from board_init_f(). Also move preloader_console_init() there to help debug issues with board_init_r(). With this spl_board_init() is no longer needed, we remove it. Tested using MMC/SD boot on OMAP-L138 LCDK board. Tested-by: Adam Ford <aford173@gmail.com> #da850evm Signed-off-by: Sekhar Nori <nsekhar@ti.com> Tested-by: Peter Howard <phoward@gme.net.au> #omapl138_lcdk
2019-05-18ARM: da850evm: Enable block cache during SPLAdam Ford
There appears to be enough RAM to support cache in SPL. This pach enables block cache in SPL. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-05-05ARM: da850evm: Enable da850-ohci USB host controllerAdam Ford
The DA850 EVM has one USB 1.1 OHCI Host controller. With the host controller now support DM_USB, this patch enables the respective functions for the da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-26ARM: da850evm: Fix TI boot scripts for MMCAdam Ford
The da850evm include environment/ti/mmc.h and places DEFAULT_MMC_TI_ARGS, defined int that file, in CONFIG_EXTRA_ENV_SETTINGS. This has been broken for some time since neither CMD_PART nor CMD_UUID are available, so manually changing the environmental variables was always required before booting from MMC. With this patch, these scripts should work again, and by default they point to mmc 0, partition 2, and the dtb file exists in a /boot directory on partition 2. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-26ARM: da850evm: Fix broken SPI FlashAdam Ford
A previous patch converted a bunch of settings for CONFIG_SF_DEFAULT but it broke the SPI Flash which now prevents booting. This patch now correctly sets CONFIG_SF_DEFAULT_SPEED=30000000 to match what it was before the conversion. Fixes: 14453fbfadc2 ("Convert CONFIG_SF_DEFAULT_* to Kconfig") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
Conflicts: arch/arm/dts/armada-385-amc.dts arch/arm/dts/armada-xp-theadorable.dts arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12ARM: davinci: da850evm: Enable SPL_OF_CONTROL without PLATDATAAdam Ford
With the memory mapping giving us some more avialable RAM, this updates the da850-evm-u-boot.dtsi to include the serial port, SPI and Flash nodes along with some dependent nodes in the SPL dtb. This also removes the platform data initialization code for the serial port and SPI Flash. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-12dm: spi: Read default speed and mode values from DTPatrick Delaunay
This patch update the behavior introduced by commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT") In case of DT boot, don't read default speed and mode for SPI from CONFIG_* but instead read from DT node. This will make sure that boards with multiple SPI/QSPI controllers can be probed at different bus frequencies and SPI modes. Remove also use in boards of the value speed=0 (no more supported) for ENV in SPI by using CONFIG_ENV_SPI_MAX_HZ=0. DT values will be always used when available (full DM support of SPI slave with available DT node) even if speed and mode are requested; for example in splash screen support (in splash_sf_read_raw) or in SPL boot (in spl_spi_load_image). The caller of spi_get_bus_and_cs() no more need to force speed=0. But the current behavior don't change if the SPI slave is not present (device with generic driver is created automatically) or if platdata is used (CONFIG_OF_PLATDATA). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-19ARM: da850evm: Increase Malloc SizeAdam Ford
The SPI NOR frameware was recently updated, but they require a little more memory that we had previosly allocated, so it stopped booting. This patch doubles the size of CONFIG_SPL_SYS_MALLOC_F_LEN to 0x800. Fixes: c4e8862308d4 ("mtd: spi: Switch to new SPI NOR framework") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-10board: da8xxevm: Add SPL DM for serial, spiJagan Teki
This patch add SPL DM support for da8xxevm boards with SPL serial, SPI drivers supported via platdata. Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Adam Ford <aford173@gmail.com> #da850evm
2018-09-29ARM: da850evm: Pinctrl for da850evmAdam Ford
The simple pin controller works for da850, so this patch enables this to pin-mux the pins defined in the device tree for the da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-29ARM: da850evm: Enable CMD_DM for da850evmAdam Ford
With DM enabled, this patch enables the 'dm' command to access the dm tree, uclass and devres. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: davinci: da850evm: Support DM_MMCAdam Ford
With the updated driver available to support DM_MMC, this patch enables DM_MMC for da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-20ARM: da850evm: Enable SPL_SYS_MALLOC_SIMPLEAdam Ford
The SPL space is limited. In order to try to enable DM in SPL, we need more space. When combined wtih TINY_PRINTF, this reduces the size of SPL by 6.5k Original: text data bss dec hex filename 20760 1216 80 22056 5628 spl/u-boot-spl Tiny Printf text data bss dec hex filename 17947 1216 80 19243 4b2b spl/u-boot-spl Malloc Simple + Tiny Printf text data bss dec hex filename 15187 176 28 15391 3c1f spl/u-boot-spl Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-20ARM: da850evm: Enable USE_TINY_PRINTFAdam Ford
The SPL space is limited. In order to try to enable DM in SPL, we need more space. This reduces the size of SPL by ~2.7K before: text data bss dec hex filename 20760 1216 80 22056 5628 spl/u-boot-spl after: text data bss dec hex filename 17947 1216 80 19243 4b2b spl/u-boot-spl Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-20configs: da850evm: Remove DM_I2C_COMPATAdam Ford
Since using DM_I2C_COMPAT throws a warning during compilation, and it isn't really needed any longer, so this patch removes this feature and shrinks the code a bit. from: text data bss dec hex filename 343326 13388 123448 480162 753a2 u-boot to: text data bss dec hex filename 342924 13380 123440 479744 75200 u-boot Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
