In order to finish moving this symbol to Kconfig for all platforms, we
need to do a few more things. First, for all platforms that define this
to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to
CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails
also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk()
and updating a few preprocessor tests.
With that done, all platforms that define a value here can be converted
to Kconfig, and a fall-back of zero is sufficiently safe to use (and
what is used today in cases where code may or may not have this
available). Make sure that code which calls this function includes
<clock_legacy.h> to get the prototype.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Enable LTO for some boards that were tested by people on U-Boot Mailing
List.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Tested-by: Adam Ford <aford173@gmail.com>
Tested-by: Pali Rohár <pali@kernel.org>
Tested-by: Tim Harvey <tharvey@gateworks.com>
CONFIG_BOOTP_SEND_HOSTNAME
Merge all outstanding changes from the current next branch in now that
we have released.
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig,
but only the non-CMD version currently does anything. This changes all
usages to prefer the CMD_MX_CYCLIC option (since it's only affecting
addition of the commands), and switches defconfigs using the non-CMD
version to use the CMD version.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
The da850-evm doesn't have the boot pins configured in a way
to make MMC/SD booting an option, and MMC/SD support is not
enabled in SPL. Therefore, there is no need to support raw mode
mmc/sd support in SPL.
This patch disables CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
[trini: Add Kconfig files]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_MX_CYCLIC
Acked-by: David Lechner <david@lechnology.com>
This patch will enable the MUSB driver to support mass storage
devices connected to the OTG port in host mode.
This patch enables MTD and CMD_MTD and it works with SPI NOR,
so the older CMD_SF can be removed.
The MTDPARTS currently lists just u-boot.ais as 512k in size.
This works when loading the ais file via serial port, but if one
wanted to update just the u-boot portion, it's not really possible.
This patch splits the MTDPARTS into a 32k SPL partiion and a 480k
u-boot partition which allows u-boot.img to be burned to the u-boot
partition. The remaining partitions are left with the same sizes
and offsets to not break backwards compatibility.
Enable the driver-model on da850-evm. We need to add a dummy nand node
to the device tree, as the real nand node is a sub-node of the aemif
device.
On linux the aemif driver populates all its child nodes, but we can't do
it in u-boot currently.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
OHCI was added with DM_USB support, so there are a few unneeded
items in the header file that can be removed. This also
unifies da850evm with NOR and NAND booting options so all have
OHCI support.
[trini: Migrate da850_am18xxevm]
Now that we removed all legacy boards selecting TI_EMAC we can
completely convert the driver code to using the driver model.
This patch also updates all remaining users of davinci_emac.
Tested-by: Adam Ford <aford173@gmail.com> #am3517-evm & da850-evm
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
U-Boot README recommends initializing SDRAM in board_init_f(). DA850
was doing it as part of board_init_r() (through call to spl_board_init()
which calls arch_cpu_init() which calls da850_ddr_setup())
This worked fine till commit 15b8c7505819 ("davinci:
da850evm/omapl138-lcdk: Move BSS to SDRAM because SRAM is full") moved
BSS to SDRAM.
Functions like mmc_initialize() called in board_init_r() assume BSS is
available. Since SDRAM was not initialized when arch/arm/lib/crt0.S tried
to initialize BSS to 0, BSS is not initialized correctly.
Fix this by simply calling arch_cpu_init() from board_init_f(). Also move
preloader_console_init() there to help debug issues with board_init_r().
With this spl_board_init() is no longer needed, we remove it.
Tested using MMC/SD boot on OMAP-L138 LCDK board.
Tested-by: Adam Ford <aford173@gmail.com> #da850evm
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Tested-by: Peter Howard <phoward@gme.net.au> #omapl138_lcdk
There appears to be enough RAM to support cache in SPL.
This pach enables block cache in SPL.
The DA850 EVM has one USB 1.1 OHCI Host controller. With the
host controller now support DM_USB, this patch enables
the respective functions for the da850evm.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
The da850evm include environment/ti/mmc.h and places
DEFAULT_MMC_TI_ARGS, defined int that file, in
CONFIG_EXTRA_ENV_SETTINGS. This has been broken for some time
since neither CMD_PART nor CMD_UUID are available, so manually
changing the environmental variables was always required before
booting from MMC. With this patch, these scripts should work
again, and by default they point to mmc 0, partition 2, and
the dtb file exists in a /boot directory on partition 2.
A previous patch converted a bunch of settings for CONFIG_SF_DEFAULT
but it broke the SPI Flash which now prevents booting. This patch
now correctly sets CONFIG_SF_DEFAULT_SPEED=30000000 to match what it
was before the conversion.
Fixes: 14453fbfadc2 ("Convert CONFIG_SF_DEFAULT_* to Kconfig")
arch/arm/dts/armada-385-amc.dts
arch/arm/dts/armada-xp-theadorable.dts
arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi
With the memory mapping giving us some more avialable RAM, this
updates the da850-evm-u-boot.dtsi to include the serial port, SPI
and Flash nodes along with some dependent nodes in the SPL dtb.
This also removes the platform data initialization code for the
serial port and SPI Flash.
This patch update the behavior introduced by
commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT")
In case of DT boot, don't read default speed and mode for SPI from
CONFIG_* but instead read from DT node. This will make sure that boards
with multiple SPI/QSPI controllers can be probed at different
bus frequencies and SPI modes.
Remove also use in boards of the value speed=0 (no more supported)
for ENV in SPI by using CONFIG_ENV_SPI_MAX_HZ=0.
DT values will be always used when available (full DM support of
SPI slave with available DT node) even if speed and mode are requested;
for example in splash screen support (in splash_sf_read_raw)
or in SPL boot (in spl_spi_load_image).
The caller of spi_get_bus_and_cs() no more need to force speed=0.
But the current behavior don't change if the SPI slave is not
present (device with generic driver is created automatically)
or if platdata is used (CONFIG_OF_PLATDATA).
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
