path: root/configs/da850_am18xxevm_defconfig
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-29ARM: da850-evm: Enable DM_I2CAdam Ford
With DM now enabled with the device tree pulled from Linux, we can enable DM_I2C in U-Boot. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add DM_I2C_COMPAT to da850_am18xxevm to fix warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-29arm: da850-evm: Enable DM and device tree support for da850-evmAdam Ford
With the device tree ported and DM compatible drivers, enable: OF_CONTROL, DM_SPI, DM_SPI_FLASH and DM_SERIAL Note: DM_SERIAL is not enabled for da850evm_direct_nor_defconfig yet. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13Convert CONFIG_MAC_ADDR_IN_SPIFLASH et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_ADDR_IN_EEPROM Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12davinci: da850-evm: switch to using TI_COMMON_CMD_OPTIONSAdam Ford
Like the OMAP-L138 LCDK before it, let's move the da850-evm and the variations to TI_COMMON_CMD_OPTIONS to cut back one some of the defconfig entries. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
