path: root/configs/d2net_v2_defconfig
2015-10-19Revert "arm: Remove d2net_v2 defconfig file"Tom Rini
Upon further review when populating README.scrapyard, d2net_v2 is a variant on net2big_v2 and not just an orphan config. To help in the future also add this to board/LaCie/net2big_v2/MAINTAINERS which needed a little consolidation anyhow. This reverts commit 1363740e7948a8e4bee8d5adcdf0f63f7782879d. Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-11arm: Remove d2net_v2 defconfig fileSimon Glass
This file appears to be an orphan with no board files. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
