path: root/configs/crownbay_defconfig
2015-09-09x86: crownbay: Convert to use CONFIG_DM_ETH for E1000Bin Meng
Since E1000 driver has been converted to driver model, enable it on Intel Crown Bay. But the Intel Topcliff GbE driver has not been converted to driver model yet, disable it for now. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-09x86: crownbay: Convert to use CONFIG_DM_USBBin Meng
Move to driver model for USB on Intel Crown Bay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Convert to use driver model pci on queensbay/crownbayBin Meng
Move to driver model pci for Intel queensbay/crownbay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14x86: Adjust config option order in defconfig for Crown Bay and MinnowmaxBin Meng
Update crownbay_defconfig and minnowmax_defconfig with 'savedefconfig' result so that the config option order matches Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: crownbay: Enable graphics supportBin Meng
Enable graphics support on Intel Crown Bay board With the help of vgabios for Intel TunnelCreek IGD. Tested with an external LVDS panel connected to X4 connector and SDVO adapter connected to X9 connector on the board. Signed-off-by: Jian Luo <jian.luo4@boschrexroth.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: crownbay: Enable writing MP tableBin Meng
Enable writing MP table for Intel Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: crownbay: Enable DM RTC supportBin Meng
Add a RTC node in the device tree to enable DM RTC support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: crownbay: Add MP initializationBin Meng
Intel Crown Bay board has a TunnelCreek processor which supports hyper-threading. Add /cpus node in the crownbay.dts and enable the MP initialization. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (modified to remove error: overriding the value of OF_CONTROL. Old value: "y", new value: "y")
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: queensbay: Implement PIRQ routingBin Meng
Implement Intel Queensbay platform-specific PIRQ routing support. The chipset PIRQ routing setup is called in the arch_misc_init(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Add crownbay defconfig and config.hBin Meng
