path: root/configs/crownbay_defconfig
2019-06-21configs: Resync with savedefconfigTom Rini
2019-03-11x86: crownbay: Enable the beeper sound driverBin Meng
Use the i8254 sound driver to support creating simple beeps. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-08-24x86: kconfig: Imply CMD_PCIBin Meng
Let's imply the 'pci' command to access the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: queensbay: kconfig: Imply platform specific driversBin Meng
Imply drivers that work with Intel Queensbay platform. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply DM uclass driversBin Meng
Now that all x86 boards have been converted to use DM, we can imply these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the top level. Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH are selected. Change to use 'imply' to allow them to be removed. Note with this change, chromebook_link64 build fails: common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build again. This is just a workaround as it is not needed at all. See commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for the same issue seen on QEMU 64-bit target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select OF_CONTROLBin Meng
This is a must have for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select PCI and DM_PCIBin Meng
PCI is the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select USE_PRIVATE_LIBGCCBin Meng
x86 is using the built-in libgcc implementation and this cannot be turned off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select TIMER and X86_TSC_TIMERBin Meng
Without a timer, U-Boot just doesn't boot. This is not something we can turn off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-30arch/x86: Select USB before selecting host driverAndy Shevchenko
Kbuild complains if USB is not selected before any of host driver. warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) Select it for X86. Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> [bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-03-21mmc: pci: Add CONFIG_MMC_PCIFelipe Balbi
We don't want pci_mmc to compile every time x86 compiles, only when there's a platform that needs it. For that reason, we're adding a new CONFIG_MMC_PCI which platforms can choose to enable. Suggested-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: crownbay: Disable boot stage supportBin Meng
It is observed that when enabling boot stage support, occasionally the board reboots during boot over and over again, and eventually boots to shell. This was seen on my board, but not on Jian's board. Debugging shows that the TSC timer calibration against PIT fails as boot stage APIs utilize timer in a very early stage and at that time TSC/PIT may not be stable enough for the calibration to pass. Disable it for now. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Cc: Jian Luo <Jian.Luo4@boschrexroth.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-17x86: gpio: Allow the pinctrl driver to set up the pin configSimon Glass
Rather than setting up the pin configuration in the GPIO driver, use the new pinctrl driver to do it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
