path: root/configs/cpu9260_defconfig
2015-09-11arm: Remove eukrea boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove all cpu9260 and cpuat91 boards. Signed-off-by: Simon Glass <sjg@chromium.org>
