path: root/configs/corvus_defconfig
2015-04-01arm, at91: corvus: move MACH_TYPE to defconfigHeiko Schocher
move MACH_TYPE into defconfig Signed-off-by: Heiko Schocher <hs@denx.de>
2014-11-17arm, spl, at91: add spl support for the corvus boardHeiko Schocher
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
