path: root/configs/coreboot_defconfig
2018-04-16x86: Rename coreboot-x86 to corebootSimon Glass
We only use coreboot as a target on x86 platforms, since on ARM platforms U-Boot always runs as the primary boot loader. Rename the coreboot-x86 platform to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
