path: root/configs/coreboot-x86_defconfig
2016-06-12x86: Enable regmap and syscon for coreboot and qemu-x86Bin Meng
These are generic and should be turned on on coreboot and qemu-x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01x86: tsc: Remove legacy timer codesBin Meng
Now that we have converted all x86 boards to use driver model timer, remove these legacy timer codes in the tsc driver. Note this also removes the TSC_CALIBRATION_BYPASS Kconfig option, as it is not needed with driver model. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: Convert to use driver model timerBin Meng
Convert all x86 boards to use driver model tsc timer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: coreboot: Convert to use more dm driversBin Meng
Move to driver model for RTC, USB and ETH on coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: Convert LPC driver to driver modelSimon Glass
Convert the tpm_tis_lpc driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-06-04x86: Change coreboot default build configuration to QEMUBin Meng
QEMU is much easier for us test booting U-Boot as a coreboot payload than having a real board like chromebook_link. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Make QEMU the default vendorBin Meng
Now that we have QEMU support, make it the default vendor in the 'make menuconfig' screen. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: x86: pci: Convert coreboot to use driver model for pciSimon Glass
Move coreboot-x86 over to driver model for PCI. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Make chromebook_link the default board for corebootBin Meng
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link which is currently the only real board officially supported to run U-Boot loaded by coreboot. Note the symbolic link file chromebook_link.dts is deleted and link.dts is renamed to chromebook_link.dts. To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86 define needs to be moved to arch/x86/cpu/ivybridge/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
