path: root/configs/coreboot-x86_defconfig
2017-08-24x86: kconfig: Imply CMD_PCIBin Meng
Let's imply the 'pci' command to access the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: coreboot: kconfig: Imply drivers that are usefulBin Meng
U-Boot as coreboot payload can run on any x86 hardware ideally. Let's imply some common drivers that are useful. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply DM uclass driversBin Meng
Now that all x86 boards have been converted to use DM, we can imply these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the top level. Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH are selected. Change to use 'imply' to allow them to be removed. Note with this change, chromebook_link64 build fails: common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build again. This is just a workaround as it is not needed at all. See commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for the same issue seen on QEMU 64-bit target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select OF_CONTROLBin Meng
This is a must have for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Let board select BOARD_EARLY_INIT_FBin Meng
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes and should be not 'default y' for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select PCI and DM_PCIBin Meng
PCI is the de facto interconnect bus in an x86 system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select USE_PRIVATE_LIBGCCBin Meng
x86 is using the built-in libgcc implementation and this cannot be turned off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select TIMER and X86_TSC_TIMERBin Meng
Without a timer, U-Boot just doesn't boot. This is not something we can turn off. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-30arch/x86: Select USB before selecting host driverAndy Shevchenko
Kbuild complains if USB is not selected before any of host driver. warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) Select it for X86. Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> [bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-12x86: coreboot: Convert to use DM coreboot video driverBin Meng
This converts coreboot to use DM framebuffer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-12x86: Enable regmap and syscon for coreboot and qemu-x86Bin Meng
These are generic and should be turned on on coreboot and qemu-x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01x86: tsc: Remove legacy timer codesBin Meng
Now that we have converted all x86 boards to use driver model timer, remove these legacy timer codes in the tsc driver. Note this also removes the TSC_CALIBRATION_BYPASS Kconfig option, as it is not needed with driver model. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: Convert to use driver model timerBin Meng
Convert all x86 boards to use driver model tsc timer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: coreboot: Convert to use more dm driversBin Meng
Move to driver model for RTC, USB and ETH on coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: Convert LPC driver to driver modelSimon Glass
Convert the tpm_tis_lpc driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
