CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
The only user of board_pex_config() weak function is A385 controlcenterdc
board. It looks like that code in its board_pex_config() function needs to
be executed after PCIe link is up. Therefore put this code into
spl_board_init() function which is called after a38x serdes initialization,
and therefore it is after the serdes hws_pex_config() function finishes
(which is the state before this change).
With this change completely remove board_pex_config() function as it is not
used anymore.
Signed-off-by: Pali Rohár <pali@kernel.org>
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SPL_DRIVERS_MISC
CONFIG_SPL_ENV_SUPPORT
CONFIG_SPL_GPIO
CONFIG_SPL_I2C
CONFIG_SPL_LDSCRIPT
CONFIG_SPL_LIBCOMMON_SUPPORT
CONFIG_SPL_LIBGENERIC_SUPPORT
CONFIG_SPL_LOAD_FIT_ADDRESS
CONFIG_SPL_MMC
CONFIG_SPL_NAND_SUPPORT
CONFIG_SPL_NO_CPU_SUPPORT
CONFIG_SPL_OS_BOOT
CONFIG_SPL_POWER
CONFIG_SPL_STACK_R
CONFIG_SPL_STACK_R_ADDR
CONFIG_SPL_WATCHDOG
CONFIG_SPL_TEXT_BASE
Resync all defconfig files using moveconfig.py
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
The gdsys a38x config file (controlcenterdc_defconfig) uses BootROM to
load U-Boot proper.
Since it is now possible to do this via U-Boot SPL framework, we do not
need to provide custom spl_board_init() which calls return_to_bootrom().
Reviewed-by: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Now that proper load and execution addresses are set in v1 kwbimage we
can use it for loading and booting U-Boot proper.
Use the new spl_parse_board_header() function to implement parsing the
kwbimage v1 header. Use information from this header to locate offset and
size of the U-Boot proper binary, instead of using the legacy U-Boot
header which is prepended to the U-Boot proper binary stored at fixed
offset. This has the advantage that we do not need to relay on legacy
U-Boot header anymore and therefore U-Boot proper binary can be stored at
any offset, as is the case when loading & booting U-Boot proper by
BootROM. The CONFIG_SYS_U_BOOT_OFFS option is therefore not used by SPL
code anymore.
Also allow to compile U-Boot SPL without CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_MMC_SUPPORT or CONFIG_SPL_SATA_SUPPORT set. In this case
BootROM is used for loading and executing U-Boot proper. This reduces the
size of U-Boot's SPL image. By default these config options are enabled
and so BootROM loading is not used. In some cases BootROM reads from SPI
NOR at lower speed than U-Boot SPL. So people can decide whether they
want to have smaller SPL binary at the cost of slower boot.
Therefore dependency on CONFIG_SPL_DM_SPI, CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_SPI_LOAD, CONFIG_SPL_SPI_SUPPORT, CONFIG_SPL_DM_GPIO,
CONFIG_SPL_DM_MMC, CONFIG_SPL_GPIO_SUPPORT, CONFIG_SPL_LIBDISK_SUPPORT,
CONFIG_SPL_MMC_SUPPORT, CONFIG_SPL_SATA_SUPPORT and
CONFIG_SPL_LIBDISK_SUPPORT is changed from strict to related "imply"
(which can be selectivelly turned off and causes booting via BootROM).
Options CONFIG_SYS_SPI_U_BOOT_OFFS,
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR and
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET have to to be set to
zero as they define the location where kwbimage header starts. It is the
location where BootROM expects start of the kwbimage from which it reads,
parses and executes SPL part. The same applies to option
CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR, which has to be set to one.
Update all config files to set correct values of these options and set
CONFIG_SYS_U_BOOT_OFFS to the correct value - the offset where U-Boot
proper starts.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_BOARD_LATE_INIT
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Update mvebu SPL boot selection mechanism for the move to driver model
usage by ensuring that the required driver support for SPI and MMC
booting is available in SPL when the respective boot method is
selected.
Previously, all mvebu boards selected a boot method (implicitly
MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used.
This changes mvebu boot method selection to depend on SPL usage which
resolves the issue with aarch64 boards which don't use SPL getting an
implicit boot device selection resulting in unmet dependencies. The
32-bit arm boards do use SPL, but I'm led to conclude that most aren't
intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have
SPL_DM_SPI enabled in their defconfig even though they still implicitly
select the SPI boot method.
This also results in the new addition of SPL_GPIO_SUPPORT to helios4.
The mainline dts for helios4 includes the cd-gpios entry for sdhci with
identical addresses as the clearfog dts. I don't have a helios4 board
to confirm, but based on the current source conclude that the board
itself is either wired to pull the signal low for eMMC, or the default
MMC boot isn't fully functional in mainline. In either case, as far as
I can tell, including the GPIO support will at least cause no
regression.
Tested on SolidRun ClearFog devices.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Several drivers used by the ControlCenterDC board were converted to DM
upstream. But the board had not been using these drivers yet.
Update the board's config file to reflect these changes and use the DM
version of these drivers. No further device tree updates are necessary,
since the devices in question are already present in the device tree.
This especially fixes the three compile warnings about CONFIG_DM_MMC,
CONFIG_DM_USB, and CONFIG_AHCI for the ControlCenterDC board.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Move some configurations in defconfig file
- CONFIG_CMD_I2C
- CONFIG_CMD_SPI
This allow correct dependency handling in Kconfig.
This patch adds DM_PCI support to the MVEBU PCIe driver. This is
necessary, since all PCI drivers have to be moved to DM (driver model)
until the v2019.07 release.
To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU
from config headers to the defconfig files.
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Phil Sutter <phil@nwl.cc>
Cc: Marek Behún <marek.behun@nic.cz>
Cc: VlaoMao <vlaomao@gmail.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
The CONFIG_PHY_MARVELL has already been migrated to Kconfig (some boards
already had it in their Kconfig), but had not been moved for older
boards.
Move it to the defconfigs for all boards.
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but
existed in some include files; fix those up here.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
