path: root/configs/controlcenterdc_defconfig
2019-05-27arm: mvebu: controlcenterdc: Update configMario Six
Several drivers used by the ControlCenterDC board were converted to DM upstream. But the board had not been using these drivers yet. Update the board's config file to reflect these changes and use the DM version of these drivers. No further device tree updates are necessary, since the devices in question are already present in the device tree. This especially fixes the three compile warnings about CONFIG_DM_MMC, CONFIG_DM_USB, and CONFIG_AHCI for the ControlCenterDC board. Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-25controlcenterdc: move some configuration in defconfig filePatrick Delaunay
Move some configurations in defconfig file - CONFIG_CMD_I2C - CONFIG_CMD_SPI This allow correct dependency handling in Kconfig. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-05pci: pci_mvebu: Add DM_PCI support and move CONFIG_PCI_MVEBU to defconfigStefan Roese
This patch adds DM_PCI support to the MVEBU PCIe driver. This is necessary, since all PCI drivers have to be moved to DM (driver model) until the v2019.07 release. To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU from config headers to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2018-04-28Cleanup CONFIG_SPL_SERIAL_SUPPORT migrationAlex Kiernan
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but existed in some include files; fix those up here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-08-11Convert CONFIG_CMD_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SCSI Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Rework to default y if SCSI, drop cl-som-am57x which did not use CMD_SCSI for real] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-23arm: mvebu: Add gdsys ControlCenter-Compact boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Marvell Armada 38x SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2 x GbE - Xilinx Kintex-7 FPGA connected via PCIe - mSATA - USB3 host - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
