path: root/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig
2016-08-16x86: conga-qeval20-qa3: Add SMBus support and SMSC2513 config codeStefan Roese
This patch includes the following changes: - Remove Designware I2C support from dts as its not used - Configure SMBus PADs in dts - Enable I2C commands and I2C support - Configure SMSC2513 USB hub via SMBus upon startup - Move environment location to match Minnowmax example - Enhancement of the default environment Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-12x86: conga-qeval20-qa3: Add support for internal UARTStefan Roese
This patch adds support to enable and use the internal BayTrail UART instead of the one integrated in the Super IO Winbond chip. For this, a 2nd defconfig file is added. This is useful for tests done for the congatec SoM used on baseboards without such a Super IO chip. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
