CONFIG_SYS_FLASH_EMPTY_INFO
CONFIG_SYS_OHCI_SWAP_REG_ACCESS
CONFIG_SYS_USB_OHCI_CPU_INIT
CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS
CONFIG_SYS_USB_OHCI_SLOT_NAME
CONFIG_USB_ATMEL
CONFIG_USB_ATMEL_CLK_SEL_PLLB
CONFIG_USB_ATMEL_CLK_SEL_UPLL
CONFIG_USB_OHCI_LPC32XX
CONFIG_USB_OHCI_NEW
CONFIG_SYS_BOOTPARAMS_LEN
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
CONFIG_PHY_RESET_DELAY
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_SYS_RX_ETH_BUFFER
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Add Kconfig files]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs.
Based on https://patchwork.ozlabs.org/patch/1019791/
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Signed-off-by: Ãlvaro Fernández Rojas <noltari@gmail.com>
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
