path: root/configs/comtrend_wap5813n_ram_defconfig
2019-01-16MIPS: bmips: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Based on https://patchwork.ozlabs.org/patch/1019791/ Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19bmips: enable wap-5813n enet supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add wap-5813n usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: select OF_EMBED for all boardsÁlvaro Fernández Rojas
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-26MIPS: add BMIPS Comtrend WAP-5813n boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
