path: root/configs/comtrend_ct5361_ram_defconfig
2018-12-19bmips: enable ct-5361 enet supportÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-03-21mips: bmips: add ct-5361 usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: select OF_EMBED for all boardsÁlvaro Fernández Rojas
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-31MIPS: add BMIPS Comtrend CT-5361 boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
