path: root/configs/comtrend_ar5387un_ram_defconfig
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-01-16MIPS: bmips: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Based on https://patchwork.ozlabs.org/patch/1019791/ Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19bmips: enable ar-5387un enet supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add ar-5387un usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: select OF_EMBED for all boardsÁlvaro Fernández Rojas
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-24mips: bmips: enable the SPI flash on the Comtrend AR-5387unÁlvaro Fernández Rojas
It's a Macronix (mx25l12805d) 16 MB SPI flash. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-10mips: bmips: enable bcm6328-power-domain driver for BCM6328 and BCM63268 boardsÁlvaro Fernández Rojas
2017-05-10mips: bmips: enable bcm6345-reset driver for all BMIPS boardsÁlvaro Fernández Rojas
2017-05-10mips: bmips: enable bcm6345-clk driver for all BMIPS boardsÁlvaro Fernández Rojas
2017-05-10mips: bmips: add Comtrend AR-5387un bcm6328-ledsÁlvaro Fernández Rojas
This board has several LEDs attached to its BCM6328 led controller. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10MIPS: add BMIPS Comtrend AR-5387un boardÁlvaro Fernández Rojas
