CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs.
Based on https://patchwork.ozlabs.org/patch/1019791/
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Signed-off-by: Ãlvaro Fernández Rojas <noltari@gmail.com>
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
