We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The colorfly e708 q1 is a 7" tablet which is clearly marked as colorfly
e708 q1 on the back. It features a 9:16 800x1280 IPS LCD, A31s SoC,
1GB RAM, 8G NAND, ilitek 2139qt004 touchscreen on i2c-1 addr 0x41,
stk8313 accelerometer on i2c-2 addr 0x22 and a rtl8188etv wifi chip.
The added dts is identical to the dts submitted to the upstream kernel,
note this commit also syncs axp22x.dtsi and sun6i-a31.dtsi with the
upstream kernel as the added dts depends on these.
