path: root/configs/colibri_vf_defconfig
2016-02-02arm: vybrid: Update defconfig'sBhuvanchandra DV
Let's go with pure DT solution for board's based on NXP/Freescale Vybrid platform. - Merge the DT defconfig with non-DT defconfig for Toradex Colibri VF50/VF61 and drop the non-DT defconfig. - Update the legacy defconfigs for NXP/Freescale VF610 Tower Board with DT. - Update the legacy defconfigs for Phytec phyCORE-vybrid Board with DT. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-06-08colibri_vf: Enable GPIO supportBhuvanchandra DV
Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-24mtd: vf610_nfc: add Freescale NFC controller configs to KconfigStefan Agner
This commit allows users to enable/disable the Freescale NFC controller found in systems like Vybrid (VF610), MPC5125, MCF54418 or Kinetis K70 via Kconfig with more detailed help docs. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Stefano Babic <sbabic@denx.de> [scottwood: updated vf610twr_nand_defconfig] Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-04-23ARM: vf610: Initial integration for Colibri VF50/VF61Sanchayan Maity
This adds initial support for Colibri VF50/VF61 based on Freescale Vybrid SoC. - CPU clocked at 396/500 MHz - DDR3 at 396MHz - for VF50, use PLL2 as memory clock (synchronous mode) - for VF61, use PLL1 as memory clock (asynchronous mode) - Console on UART0 (Colibri UART_A) - Ethernet on FEC1 - PLL5 based RMII clocking (E.g. No external crystal) - UART_A and UART_C I/O muxing - Boot from NAND by default Tested on Colibri VF50/VF61 booting using serial loader over UART. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Stefan Agner <stefan@agner.ch>
