This allows to boot from SD/USB with passing the rootfs partition via UUID.
Enable DM_VIDEO for Colibri VF.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Extend size of the malloc() pool for use before relocation, from 0x400
(default one) to 0x2000 (CONFIG_SYS_MALLOC_F_LEN=0x2000),
as adding of DM_FLAG_PRE_RELOC flag to simple-bus driver introduced a
regression on multiple boards, because of more intensive usage of malloc()
pool and therefore a broken boot as the size of pool isn't sufficient.
Fixes: 3a7c45f6a7 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus")
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from
KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns
that you shouldn't select both of them due to a device ID clash between
the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a
system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately
boards like the SAMA5D3xEK do contain both types of PHY, but fortunately
the Linux Micrel PHY driver provides a solution by using different PHY
ID and mask values to distinguish these chips.
This commit contains the following changes:
- The PHY ID and mask values for the KSZ9021 and the KS8721 now match
those used by the Linux driver.
- The warnings about not enabling both drivers have been removed.
- The description for PHY_MICREL_KSZ8XXX has been corrected (these are
10/100 PHYs, not GbE PHYs).
- PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE
since this is selected by PHY_MICREL_KSZ90X1.
- All of the relevant defconfig files have been updated now that
PHY_MICREL_KSZ8XXX does not default to 'Y'.
Signed-off-by: James Byrne <james.byrne@origamienergy.com>
Use device tree to set MTD partitions of the NAND chip.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Migrate FEC, ESDHC, NFC and USB to driver model.
While at it also do no longer enable optional I2C clock in board file as
the generic clock code now handles this. Note for space reason and as
it is not required just for booting we do not enable I2C in U-Boot by
default.
While at it also update copyright period.
Migrate pinctrl and regulators to device tree resp. driver model: DDR,
DSPI, ENET, ESDHC, I2C, NFC and UART.
Enable CMD_DM, PINCTRL and DM_REGULATOR.
While at it also update copyright period and sort include files.
Disable more obscure options to save another 26 KB in preparation of
the upcoming driver model migration.
Limit the size of the malloc() pool before relocation
(SYS_MALLOC_F_LEN).
Safe some space by not selecting CMD_NFS and CMD_LOADS/B.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Drop SPI support saving precious 4 Kb on boards with tough size
restrictions.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Unset CONFIG_CMDLINE_EDITING saving precious 4 Kb on boards with tough
size restrictions.
Unset CONFIG_EFI_UNICODE_CAPITALIZATION on boards with tough size
restrictions.
This is analogous to commit a90bf07afc43
("efi_loader: unset CONFIG_EFI_UNICODE_CAPITALIZATION").
Reviewed-by: Alexander Graf <agraf@suse.de>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
[trini: Re-run migration]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_FUSE
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Toradex Colibri Vybrid
module.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
configs/bk4r1_defconfig
configs/colibri_vf_defconfig
configs/pcm052_defconfig
include/configs/colibri_vf.h
include/configs/pcm052.h
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Device tree overlays might prove useful in the future, enable it
by default on all Toradex modules.
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for
various reasons. We also have cases where we only build SPL in Thumb2 mode due
to size constraints and wish to build the rest of the system in ARM mode. So
in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to
control if we build everything or just SPL (or in theory, just U-Boot) in
Thumb2 mode.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
