path: root/configs/colibri_imx7_defconfig
2019-10-08imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HABStefano Babic
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc. Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-10-04Kconfig: Migrate CONFIG_BOOTM_* optionsTom Rini
Migrate all of the existing OS support options that are under CONFIG_BOOTM_* to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-29configs: colibri_imx7: enable DM_VIDEOIgor Opaniuk
Enable DM_VIDEO support for Colibri iMX7 NAND version. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-21configs: Resync with savedefconfigTom Rini
2019-06-14net: Convert CONFIG_TFTP_BLOCKSIZE to KconfigMarek Vasut
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs, headers and whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-14net: Convert CONFIG_IP_DEFRAG to KconfigMarek Vasut
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers and whitelist. This patch is a follow-up on a patch by Christian Gmeiner with the added config/header/whitelist updates. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-11colibri_imx7: migrate usb to driver modelIgor Opaniuk
Migrate USB to Driver Model (CONFIG_DM_USB=y). Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11toradex apalis/colibri: extend CONFIG_SYS_MALLOC_F_LENIgor Opaniuk
Extend size of the malloc() pool for use before relocation, from 0x400 (default one) to 0x2000 (CONFIG_SYS_MALLOC_F_LEN=0x2000), as adding of DM_FLAG_PRE_RELOC flag to simple-bus driver introduced a regression on multiple boards, because of more intensive usage of malloc() pool and therefore a broken boot as the size of pool isn't sufficient. Fixes: 3a7c45f6a7 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus") Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-14net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used togetherJames Byrne
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips. This commit contains the following changes: - The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-28configs: colibri_imx7: use distro defaultsStefan Agner
The defconfig already use most features implied by distro defaults. Make sure we enable all features required by distro boot by making use of CONFIG_DISTRO_DEFAULTS. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-01-28configs: colibri_imx7: use DFU for NAND instead of MMCStefan Agner
The colibri_imx7_defconfig is for Colibri iMX7 raw NAND devices. Hence DFU for NAND is more useful then for MMC devices. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-01-28configs: colibri_imx7: enable CAAM driverStefan Agner
Access to CAAM in non-secure mode must be enabled by the boot loader first. The U-Boot CAAM driver enables access to CAAM in non-secure mode by default. Hence enable the CAAM driver to allow Linux accessing CAAM directly. This prevents error messages like the following on Linux boot: caam 30900000.caam: Entropy delay = 3200 caam 30900000.caam: failed to acquire DECO 0 caam 30900000.caam: failed to instantiate RNG Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-28configs: colibri_imx7: use DM_MMCStefan Agner
Now that device tree is in place use DM_MMC for Colibri iMX7 devices. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-28configs: colibri_imx7: use separate device treeStefan Agner
Use OF_SEPARATE as suggested by the build system. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-28configs: colibri_imx7: enable DM for raw NAND devicesStefan Agner
Use DM and device trees for raw NAND devices by default. This fixes -74 NAND read errors since it makes sure the ECC settings are the same as used in Linux and our downstream U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-01-28arm: dts: imx7: colibri: split dt for raw NAND and eMMC devicesStefan Agner
In preparation of adding CONFIG_DM_MMC support use separate device trees for raw NAND and eMMC devices. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-03-19Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/bk4r1_defconfig configs/colibri_vf_defconfig configs/pcm052_defconfig include/configs/colibri_vf.h include/configs/pcm052.h
2017-03-19colibri_imx7: use device-tree for MTD partitionsStefan Agner
Use device-tree fixup to communicate the MTD partitions to the kernel. Remove mtdparts from the kernel command line. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-03-19toradex apalis/colibri: add device tree overlay supportStefan Agner
Device tree overlays might prove useful in the future, enable it by default on all Toradex modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-03-19toradex apalis/colibri: use common USB product id fallbackStefan Agner
All modules use the common g_dnl_bind_fixup implementaton which calculates the PID according to product id (read from the config block) plus offset of 0x4000. In case there is no config block support (e.g. SPL) or in case the config block is not readable, fall back to a generic product id (product id 0, which can be interpreted as "Unknown Module"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
