2018-09-28 | colibri imx6: use dynamic ddr calibration | Max Krummenacher | |
Some Colibri iMX6 IT were found which were freezing at higher temperature. Using the SPL to do a dynamic calibration at each boot fixes the issue. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2018-07-27 | colibri_imx6: add configuration for tezi | Stefan Agner | |
Modify configuration for Tezi: - Enable SDP in SPL and U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Remove video output - Use distroboot by default - Boot from external SD cards by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> |
