Use CONFIG_DM_VIDEO=y by default for Colibri iMX6ULL.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
We never really added a sensible DFU configuration for platforms
based on eMMC. Most of the things one might want to do can also be done
with UMS or fastboot, so drop the DFU configuration.
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Extend size of the malloc() pool for use before relocation, from 0x400
(default one) to 0x2000 (CONFIG_SYS_MALLOC_F_LEN=0x2000),
as adding of DM_FLAG_PRE_RELOC flag to simple-bus driver introduced a
regression on multiple boards, because of more intensive usage of malloc()
pool and therefore a broken boot as the size of pool isn't sufficient.
Fixes: 3a7c45f6a7 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus")
Porting to DM and i.MX8
- warp7 to DM
- kp_imx53 to DM
- Warnings in DT
- MX8QM support
- colibri-imx6ull to DM
- imx7d-pico to DM
- ocotp for MX8
Migrate Ethernet FEC to using driver model.
Drop PHY_MICREL_KSZ90X1 which slipped in from Apalis iMX6.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Migrate USB to using driver model.
Add USBH_PEN GPIO regulator.
While at it also add alias e.g. as required for UMS.
Migrate MMC to using driver model.
Migrate USDHC to using pinctrl.
While at it also add GPIO1_IO03__OSC32K_32K_OUT pin muxing.
While at it also update copyright period.
Migrate pinctrl and regulators to device tree resp. driver model:
Ethernet, NAND and UART.
Drop BOARD_EARLY_INIT_F as it is anyway no longer used.
Enable CMD_DM, CMD_MTD, CMD_REGULATOR and DM_REGULATOR_FIXED.
Drop disabling SPL_SYS_THUMB_BUILD as we anyway do not use SPL.
Enbale CRC32 verify, USB SDP and EFI loader support.
Drop CMD_GPT and disabling RANDOM_UUID.
Do savedefconfig which drops USB_FUNCTION_SDP.
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
trini: Update colibri-imx6ull to use Kconfig for mtdparts related
options.
Add support for the Colibri iMX6ULL module which comes with
on-board raw NAND.
