The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Update the distro config env memory layout for the Apalis iMX6,
Colibri iMX6, Colibri iMX6ULL and Colibri iMX7:
- loadaddr=0x84200000 (resp. 0x14200000 on them i.MX 6) allows for 64MB
area for uncompressing (ie FIT images)
- fdt_addr_r = loadaddr + 64MB : allows for 64MB kernel
- scriptaddr = fdt_addr_r + 512KB : allows for 512KB fdt
- pxefile_addr_r = scriptaddr + 512KB : allows for 512KB script
- ramdisk_addr_r = pxefile_addr_r + 512KB : allows for 1MB extlinux.conf
Memory layout analogous to 64-bit one from commit fd5c7173ade4
("imx8m{m,n}_venice: update env memory layout") but left pxefile_addr_r
updated according to doc/develop/distro.rst.
This fixes a potential issue caused by the compressed kernel being
relocated on top of the ramdisk causing its corruption.
Synchronise device tree with linux v5.19-rc5.
Please note that this also means that instead of the previous "generic"
U-Boot specific carrier board agnostic device trees we are now using the
regular ones for the Colibri Evaluation (carrier) board V3 (e.g.
imx6ull-colibri-eval-v3.dtb rather than the previous imx6ull-colibri.dtb
and imx6ull-colibri-emmc-eval-v3.dtb rather than the previous
imx6ull-colibri-emmc.dtb).
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Resync all defconfig files using moveconfig.py
In case a customer wants to set fdtfile currently preboot overrides it
always with preboot just before the bootdelay. Use test -n to check
if fdtfile is already set and only set it if nothing got touched manually
Add missing support of FIT-images and enable a verbosity for
this feature.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
As video support is very specific depending on the exact display
customisation we decided to disable video support for all out modules
by default.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Use the Micrel KSZ8xxx specific Ethernet PHY driver rather than the
generic one.
CONFIG_VIDEO_LOGO
Note that this option depends on CONFIG_DM_VIDEO now, since cfb_console is
deprecated. The only relevant code is now in splash.c
Drop the check for DM_VIDEO in that file.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Add code to build the eMMC variant of the Colibri iMX6ULL, i.e. the
'Colibri iMX6ULL 1GB' which has a eMMC instead of the raw NAND used
on other SKUs.
Related-to: ELB-4056, ELB-4057
