path: root/configs/cm_t43_defconfig
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_OMAP_USB_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP_USB_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-09am33xx: Finish migration of CONFIG_AM33XX/AM43XXTom Rini
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish moving the last few over to Kconfig, and put all of the boards under the appropriate Kconfig chocie now. This board choice is non-optional, so remove that keyword on am33xx. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_MTD_SUPPORT to KconfigSimon Glass
