path: root/configs/cm_t3517_defconfig
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-06omap3: cm-t3517: add basic board supportIgor Grinberg
CompuLab cm-t3517 is Computer on Module (CoM) based on AM3517 SoC. Features: up to 256MB DDR2, up to 512MB NAND, USB hub, mUSB, WiFi, BT, Analog audio codec, touch screen controller, LED. Add basic support including: LED, Serial console, NAND, MMC, GPIO, I2C, 256MB DRAM. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
