CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
bf533-stamp, bf538f-ezkit, and cm-bf548 are very space limited.
This was introduced by:
6e0d26c0502e (net: Handle ethaddr changes as an env callback)
by enabling CONFIG_REGEX, which is too big for these boards.
This patch disables CONFIG_REGEX at the expense of working with more
than the first ethaddr.
them from include/configs.
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies)
accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards.
Prior to that commit, those boards defined CONFIG_LIB_RAND, but not
CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have
touched them, but in fact it ripped CONFIG_LIB_RAND off from all the
header files, which caused undefined reference to srand and rand.
CONFIG_LIB_RAND=y must be revived for such boards.
BTW, this commit indeed makes it better, but even with this fix,
three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not
build due to region 'ram' overflowed error. This was cause by
commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs)
because CMD_NET selects NET, and NET selects REGEX. Eventually,
some boards were newly enabled with CONFIG_REGEX, increasing the
memory footprint. A patch is expected to fix the build error.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
