Now that we can use devicetree to specify this information, drop the old
CONFIG options.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Enable the mvpp2 network driver for the Armada 8K SoC.
Enable the Marvell PHY driver for the on-board 1512 PHY.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
An NVME drive may be installed on the MACCHIATObin board using the PCIe
slot or on the Clearfog Pro using mini a PCI-e slot. With the configuration
change it becomes usable.
Commit 2b4d964718c0 ("arm64: mvebu: a8k: autodetect RAM size") added an
ATF query to get the detected RAM size on Armada 8K platforms. To be
usable we must have 2 DRAM banks. Set Armada 8K configurations to 2
banks.
Cc: Konstantin Porotchkin <kostap@marvell.com>
The SolidRun Clearfog GT-8K is based on Armada 8040.
https://wiki.solid-run.com/doku.php?id=products:a8040:clearfoggt8k
The config file is identical to the Macchiatobin one
(mvebu_mcbin-88f8040_defconfig) with only the default device-tree
changed.
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
