path: root/configs/clearfog_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-06configs: Resync with savedefconfigTom Rini
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-22arm: mvebu: clearfog: enable bubt commandJoel Johnson
With support added for Armada 38x, include the bubt command in ClearFog defconfig. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Stefan Roese <sr@denx.de>
2020-04-22arm: mvebu: correct SPL boot configs for SPI/MMCJoel Johnson
Update mvebu SPL boot selection mechanism for the move to driver model usage by ensuring that the required driver support for SPI and MMC booting is available in SPL when the respective boot method is selected. Previously, all mvebu boards selected a boot method (implicitly MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used. This changes mvebu boot method selection to depend on SPL usage which resolves the issue with aarch64 boards which don't use SPL getting an implicit boot device selection resulting in unmet dependencies. The 32-bit arm boards do use SPL, but I'm led to conclude that most aren't intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have SPL_DM_SPI enabled in their defconfig even though they still implicitly select the SPI boot method. This also results in the new addition of SPL_GPIO_SUPPORT to helios4. The mainline dts for helios4 includes the cd-gpios entry for sdhci with identical addresses as the clearfog dts. I don't have a helios4 board to confirm, but based on the current source conclude that the board itself is either wired to pull the signal low for eMMC, or the default MMC boot isn't fully functional in mainline. In either case, as far as I can tell, including the GPIO support will at least cause no regression. Tested on SolidRun ClearFog devices. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Stefan Roese <sr@denx.de>
2020-04-14arm: mvebu: clearfog: move ENV params to KconfigJoel Johnson
Migrate the values for ENV_SIZE and ENV_OFFSET into board specific Kconfig defaults so they're more accessible for configuration. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Stefan Roese <sr@denx.de>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-21ARM: mvebu: clearfog: add support for EEPROM TLV infoBaruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de>
2020-01-16arm: mvebu: clearfog: set uboot image SD card offsetBaruch Siach
Armada 38x ROM skips the first SD card offset when loading SPL. This affects the location of the main U-Boot image. SPL MMC code now supports U-Boot image offset based on run-time detection of the boot partition. Use this feature to make the same generated image support both SD card and eMMC boot partition. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2020-01-16configs: clearfog: enable SPL_DM_GPIO to fix boot from SDBaruch Siach
SPL needs DM GPIO to read the SD card-detect signal. This complements the fix in commit 70bae02f71d4 ("arm: mvebu: clearfog: fix boot from SD card"). Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-09arm: mvebu: clearfog: Enable BLK and DM supportStefan Roese
This patch enables CONFIG_BLK and some DM enabled drivers on clearfog to remove these compile warnings: ===================== WARNING ====================== This board does not use CONFIG_DM_MMC. Please update the board to use CONFIG_DM_MMC before the v2019.04 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ==================================================== ===================== WARNING ====================== This board does not use CONFIG_DM_USB. Please update the board to use CONFIG_DM_USB before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ==================================================== ===================== WARNING ====================== This board does use CONFIG_LIBATA but has CONFIG_AHCI not enabled. Please update the storage controller driver to use CONFIG_AHCI before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ==================================================== Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: SĂ©bastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-07Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- SPI-NOR support
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-05pci: pci_mvebu: Add DM_PCI support and move CONFIG_PCI_MVEBU to defconfigStefan Roese
This patch adds DM_PCI support to the MVEBU PCIe driver. This is necessary, since all PCI drivers have to be moved to DM (driver model) until the v2019.07 release. To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU from config headers to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-16configs: Enable THUMB2 on various ARM boardsTom Rini
The clearfog, corvus, wb45n and picosam9g45 configs are close to exceeding their size limits, so enable THUMB2 builds on them to reclaim space. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05arm: mvebu: switch clearfog to use device-tree i2c and gpioJon Nettleton
This switches the clearfog boards to use DM based gpio and i2c drivers. The io expanders are configured via their device-tree entries. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: add DT i2c aliases] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05arm: mvebu: enable sata support for clearfogJon Nettleton
The a38x sata interfaces run in ahci mode and can be accessed via the scsi command. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: rebase on current upstream] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-30configs: clearfog: enable random random MAC addressBaruch Siach
This makes the network devices usable when booting a blank board over UART, with no pre-configured MAC address stored in the environment area. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-16arm: mvebu: clearfog: Fix SPI-NOR flash accessJon Nettleton
The production variant of the SPI flash used by the clearfog devices are based on winbond chips. Additionally enable SPI_FLASH_BAR since some variants will have 16MB of flash that requires this to be enabled. Remove the default speed and mode; these values are taken from the device tree when CONFIG_DM_SPI_FLASH is enabled. Add default bus, so that 'sf' detects the SPI flash by default. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: remove speed/mode; add bus; move winbond to defconfig] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-16arm: mvebu: clearfog: enable XHCI USBJon Nettleton
Enable the driver by default for the clearfog boards since the external port is configured for XHCI. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: split from the SoC setup patch] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
