path: root/configs/clearfog_defconfig
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-31clearfog: add HUSH parserPeter Robinson
In the big move of CONFIG_HUSH_PARSER to config files the clearfog somehow missed out. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: Add SolidRun ClearFog Armada 38x initial supportStefan Roese
This patch adds basic support for the SolidRun ClearFog Armada 38x based board to mainline U-Boot. Supported interfaces / devices are: - DDR3 - UART - MMC - Ethernet port 0 (connected to dedicated PHY) - I2C The included DT source was taken from Russell King's ftp server: http://www.home.arm.linux.org.uk/~rmk/clearfog/ With only minor modifications, like the addition of some aliases and the "u-boot,dm-pre-reloc" property. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Rabeeh Khoury <rabeeh@solid-run.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
