The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Resync all defconfig files using moveconfig.py
CONFIG_ENV_MIN_ENTRIES
CONFIG_ENV_MAX_ENTRIES
Cc: Michal Simek <michal.simek@amd.com>
CONFIG_SPL_BSS_START_ADDR
CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_SYS_MALLOC_SIMPLE
The problem here is that a few platforms have been doing:
#ifdef CONFIG_SPL_BUILD
#define CONFIG_SYS_MALLOC_SIMPLE
#endif
instead of defining CONFIG_SPL_SYS_MALLOC_SIMPLE directly. Correct this
and update the documentation in a few places to match usage.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_MAXARGS
UART base address is located in internal registers.
Internal registers for 32-bit mvebu boards in SPL are at address 0xd0000000
and in proper U-Boot at address 0xf1000000.
Fix DEBUG_UART_BASE option for all 32-bit mvebu boards.
Signed-off-by: Pali Rohár <pali@kernel.org>
Use the modern DM MDIO API for connecting PHY in the mvneta driver.
This requires enabling MVMDIO driver in several config files.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
This command is useful in U-boot scripts and it is being used by
OpenWrt bootscript for this board [1]. Otherwise shell scripting
commands are enabled by default in cmd/Kconfig.
[1] https://github.com/openwrt/openwrt/blob/852126680e21edc71c0c66561ae5a6d7479dcc67/target/linux/mvebu/image/clearfog.bootscript#L7
[2] https://source.denx.de/u-boot/u-boot/-/blob/e95afa56753cebcd20a5114b6d121f281b789006/cmd/Kconfig#L1504
Fixes: 0299c90f396c5b2971a4bac596339f4b03661c27 ("arm: mvebu: Add
SolidRun ClearFog Armada 38x initial support")
Signed-off-by: Josef Schlehofer <pepe.schlehofer@gmail.com>
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ARP_TIMEOUT
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Now that proper load and execution addresses are set in v1 kwbimage we
can use it for loading and booting U-Boot proper.
Use the new spl_parse_board_header() function to implement parsing the
kwbimage v1 header. Use information from this header to locate offset and
size of the U-Boot proper binary, instead of using the legacy U-Boot
header which is prepended to the U-Boot proper binary stored at fixed
offset. This has the advantage that we do not need to relay on legacy
U-Boot header anymore and therefore U-Boot proper binary can be stored at
any offset, as is the case when loading & booting U-Boot proper by
BootROM. The CONFIG_SYS_U_BOOT_OFFS option is therefore not used by SPL
code anymore.
Also allow to compile U-Boot SPL without CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_MMC_SUPPORT or CONFIG_SPL_SATA_SUPPORT set. In this case
BootROM is used for loading and executing U-Boot proper. This reduces the
size of U-Boot's SPL image. By default these config options are enabled
and so BootROM loading is not used. In some cases BootROM reads from SPI
NOR at lower speed than U-Boot SPL. So people can decide whether they
want to have smaller SPL binary at the cost of slower boot.
Therefore dependency on CONFIG_SPL_DM_SPI, CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_SPI_LOAD, CONFIG_SPL_SPI_SUPPORT, CONFIG_SPL_DM_GPIO,
CONFIG_SPL_DM_MMC, CONFIG_SPL_GPIO_SUPPORT, CONFIG_SPL_LIBDISK_SUPPORT,
CONFIG_SPL_MMC_SUPPORT, CONFIG_SPL_SATA_SUPPORT and
CONFIG_SPL_LIBDISK_SUPPORT is changed from strict to related "imply"
(which can be selectivelly turned off and causes booting via BootROM).
Options CONFIG_SYS_SPI_U_BOOT_OFFS,
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR and
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET have to to be set to
zero as they define the location where kwbimage header starts. It is the
location where BootROM expects start of the kwbimage from which it reads,
parses and executes SPL part. The same applies to option
CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR, which has to be set to one.
Update all config files to set correct values of these options and set
CONFIG_SYS_U_BOOT_OFFS to the correct value - the offset where U-Boot
proper starts.
Reviewed-by: Marek Behún <marek.behun@nic.cz>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
With support added for Armada 38x, include the bubt command in
ClearFog defconfig.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
Update mvebu SPL boot selection mechanism for the move to driver model
usage by ensuring that the required driver support for SPI and MMC
booting is available in SPL when the respective boot method is
selected.
Previously, all mvebu boards selected a boot method (implicitly
MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used.
This changes mvebu boot method selection to depend on SPL usage which
resolves the issue with aarch64 boards which don't use SPL getting an
implicit boot device selection resulting in unmet dependencies. The
32-bit arm boards do use SPL, but I'm led to conclude that most aren't
intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have
SPL_DM_SPI enabled in their defconfig even though they still implicitly
select the SPI boot method.
This also results in the new addition of SPL_GPIO_SUPPORT to helios4.
The mainline dts for helios4 includes the cd-gpios entry for sdhci with
identical addresses as the clearfog dts. I don't have a helios4 board
to confirm, but based on the current source conclude that the board
itself is either wired to pull the signal low for eMMC, or the default
MMC boot isn't fully functional in mainline. In either case, as far as
I can tell, including the GPIO support will at least cause no
regression.
Tested on SolidRun ClearFog devices.
Migrate the values for ENV_SIZE and ENV_OFFSET into board specific
Kconfig defaults so they're more accessible for configuration.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Armada 38x ROM skips the first SD card offset when loading SPL. This
affects the location of the main U-Boot image. SPL MMC code now supports
U-Boot image offset based on run-time detection of the boot partition.
Use this feature to make the same generated image support both SD card
and eMMC boot partition.
SPL needs DM GPIO to read the SD card-detect signal. This complements
the fix in commit 70bae02f71d4 ("arm: mvebu: clearfog: fix boot from SD
card").
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
This patch enables CONFIG_BLK and some DM enabled drivers on clearfog
to remove these compile warnings:
===================== WARNING ======================
This board does not use CONFIG_DM_MMC. Please update
the board to use CONFIG_DM_MMC before the v2019.04 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
This board does not use CONFIG_DM_USB. Please update
the board to use CONFIG_DM_USB before the v2019.07 release.
This board does use CONFIG_LIBATA but has CONFIG_AHCI not
enabled. Please update the storage controller driver to use
CONFIG_AHCI before the v2019.07 release.
