path: root/configs/cl-som-imx7_defconfig
2020-06-22ARM: imx: soc: Select default TEXT_BASE for MX7Marek Vasut
Select default U-Boot and SPL text base for the MX7 SoC. The U-Boot text base is picked as the one used by various MX7 boards. The SPL text base however is different. The SPL text base is set to 0x912000 instead of the usual 0x911000, that is because the 0x911000 value cannot work. Using 0x911000 as a SPL text base will result in the DCD header being placed below the 0x911000 address, which is a reserved SRAM area which must not be used. This will actually trigger eMMC boot failure on MX7D at least. Hence the increment. Update all boards affected by this SPL problem to the new SPL_TEXT_BASE. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2020-06-04Convert CONFIG_BOARD_LATE_INIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_LATE_INIT Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-04Convert CONFIG_CMD_ASKENV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMD_ASKENV CONFIG_CMD_BMP CONFIG_CMD_BOOTD CONFIG_CMD_CACHE CONFIG_CMD_CRC32 CONFIG_CMD_DHCP CONFIG_CMD_ENV CONFIG_CMD_EXPORTENV CONFIG_CMD_EXT2 CONFIG_CMD_EXT4 CONFIG_CMD_FLASH CONFIG_CMD_FS_GENERIC CONFIG_CMD_FUSE CONFIG_CMD_GPIO CONFIG_CMD_GPT CONFIG_CMD_GREPENV CONFIG_CMD_I2C CONFIG_CMD_IMLS CONFIG_CMD_IMPORTENV CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_CMD_MEMINFO CONFIG_CMD_MII CONFIG_CMD_MTDPARTS CONFIG_CMD_NAND CONFIG_CMD_NAND_TRIMFFS CONFIG_CMD_NFS CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PING CONFIG_CMD_READ CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_SPL CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_TIME CONFIG_CMD_TRACE CONFIG_CMD_UBI CONFIG_CMD_UBIFS CONFIG_CMD_UNZIP CONFIG_FS_EXT4 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-10-04Kconfig: Migrate CONFIG_BOOTM_* optionsTom Rini
Migrate all of the existing OS support options that are under CONFIG_BOOTM_* to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2019-01-01arm: imx7d: cl-som-imx7: migration to CONFIG_BLKYaniv Levinsky
Enable driver model for USB, MMC and REGULATOR drivers. Set run-time configuration via Device Tree. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il>
2018-07-23arm: imx7d: cl-som-imx7: sf: support all SF typesUri Mashiach
Enable the support for all SPI flash types. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il>
2018-06-27cl-som-imx7: Remove CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=yFabio Estevam
Since commit 1da1938d57b3 ("spl: Add default values for ARCH_MX7") CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is selected by default on i.MX7 platforms, so remove it from the board defconfig. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-01-27env: Allow to build multiple environments in KconfigMaxime Ripard
Now that we have everything in place in the code, let's allow to build multiple environments backend through Kconfig. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-12arm: imx7d: add support for Compulab cl-som-imx7Ilya Ledvich
Add initial support for Compulab cl-som-imx7 SoM. The initial support includes: - MMC - eMMC - SPI flash - I2C - FEC - USB - Serial console Signed-off-by: Ilya Ledvich <ilya@compulab.co.il>
