path: root/configs/cl-som-am57x_defconfig
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-02arm: am57xx: cl-som-am57x: add initial board supportDmitry Lifshitz
Features supported : * Serial console * SPI Flash * MMC/SD Card * eMMC storage * SATA * PCA9555 - GPIO expander over I2C5 bus * USB Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> [uri.mashiach@compulab.co.il: Adjust to v2016.11] Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
