path: root/configs/chromebox_panther_defconfig
2015-10-21x86: Move mrccache.[c|h] to a common placeBin Meng
mrccache implementation can be common for all boards. Move it from ivybridge cpu directory to the common lib directory. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: Convert LPC driver to driver modelSimon Glass
Convert the tpm_tis_lpc driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05x86: Move Chrome OS options to defconfigSimon Glass
Drop these from the header file and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28x86: Enable DM RTC support for all x86 boardsBin Meng
Add a RTC node in the device tree to enable DM RTC support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> (Squashed in 'x86: Fix RTC build error on ivybridge')
2015-07-14x86: Move VGA option rom macros to KconfigBin Meng
Move X86_OPTION_ROM_FILE & X86_OPTION_ROM_ADDR to arch/x86/Kconfig and rename them to VGA_BIOS_FILE & VGA_BIOS_ADDR which depend on HAVE_VGA_BIOS. The new names are consistent with other x86 binary blob options like HAVE_FSP/FSP_FILE/FSP_ADDR. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: x86: pci: Convert chromebook_link to use driver model for pciSimon Glass
Move chromebook_link over to driver model for PCI. This involves: - adding a uclass for platform controller hub - removing most of the existing PCI driver - adjusting how CPU init works to use driver model instead - rename the lpc compatible string (it will be removed later) This does not really take advantage of driver model fully, but it does work. Furture work will improve the code structure to remove many of the explicit calls to init the board. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16x86: Add support for panther (Asus Chromebox)Simon Glass
Support running U-Boot as a coreboot payload. Tested peripherals include: - Video (HDMI and DisplayPort) - SATA disk - Gigabit Ethernet - SPI flash USB3 does not work. This may be a problem with the USB3 PCI driver or something in the USB3 stack and has not been investigated So far this is disabled. The SD card slot also does not work. For video, coreboot will need to run the OPROM to set this up. With this board, bare support (running without coreboot) is not available as yet. Signed-off-by: Simon Glass <sjg@chromium.org>
