Add a RTC node in the device tree to enable DM RTC support.
(Squashed in 'x86: Fix RTC build error on ivybridge')
Move X86_OPTION_ROM_FILE & X86_OPTION_ROM_ADDR to arch/x86/Kconfig
and rename them to VGA_BIOS_FILE & VGA_BIOS_ADDR which depend on
HAVE_VGA_BIOS. The new names are consistent with other x86 binary
blob options like HAVE_FSP/FSP_FILE/FSP_ADDR.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define
the text base address. Since it is deprecated, just remove it and use
CONFIG_SYS_TEXT_BASE directly.
Let arch/x86/Kconfig prompt board vendor first, then select
the board model under that vendor. This way arch/x86/Kconfig
only needs concern board vendor and leave the supported target
list to board/<vendor>/Kconfig.
Move chromebook_link over to driver model for PCI.
This involves:
- adding a uclass for platform controller hub
- removing most of the existing PCI driver
- adjusting how CPU init works to use driver model instead
- rename the lpc compatible string (it will be removed later)
This does not really take advantage of driver model fully, but it does work.
Furture work will improve the code structure to remove many of the explicit
calls to init the board.
Support running U-Boot as a coreboot payload. Tested peripherals include:
- Video (HDMI and DisplayPort)
- SATA disk
- Gigabit Ethernet
- SPI flash
USB3 does not work. This may be a problem with the USB3 PCI driver or
something in the USB3 stack and has not been investigated So far this is
disabled. The SD card slot also does not work.
For video, coreboot will need to run the OPROM to set this up.
With this board, bare support (running without coreboot) is not available
as yet.
