path: root/configs/chromebook_speedy_defconfig
2020-10-09configs: Resync with savedefconfigTom Rini
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-06Merge branch 'next'Tom Rini
Merge all outstanding changes from the current next branch in now that we have released.
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-05-22defconfig: veyron: no need for CONFIG_SPL_PINCTRL_FULLUrja Rannikko
Veyrons do not need full pinctrl support for SPL. The full pinctrl support does nothing when enabled with OF_PLATDATA, thus was already unused. This frees about 4kB of SPL size. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-22rockchip: veyron: move board_early_init_f to _r (after reloc)Urja Rannikko
Previously veyron_init() was called in board_init() context, which is called after relocation. Moving it to veyron.c used board_early_init_f which is called way earlier, and causes veyron_init to hang. Using board_early_init_r instead fixes this. Fixes: b678f2790c ("rockchip: rk3288: Move veyron_init() back to veyron.c") Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-11configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-19configs: update rk3288 veyron defconfigsUrja Rannikko
Updates jerry, mickey, minnie and speedy defconfigs to: - fit the SPL in 32k - boot from SPI (only) - remove gadget support (these have no OTG port) Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> (Rebase on top of tree) Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-19configs: Move CONFIG_SPI_FLASH_GIGADEVICE properly into KconfigUrja Rannikko
Affects rk3288 veyrons and rk3036, this was mostly done by moveconfig.py. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-20rockchip: rk3288: use default value for SYS_MALLOC_F_LENKever Yang
There is no difference in rk3288 board use for SYS_MALLOC_F_LEN, so we can use default value. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-02-01rockchip: add support for veyron-speedy (ASUS Chromebook C201)Marty E. Plummer
This adds support for the ASUS C201, a RK3288-based clamshell device. The device tree comes from linus's linux tree at 3f16503b7d2274ac8cbab11163047ac0b4c66cfe. The SDRAM parameters are for 4GB Samsung LPDDR3, decoded from coreboot's src/mainboard/google/veyron/sdram_inf/sdram-lpddr3-samsung-4GB.inc Signed-off-by: Marty E. Plummer <hanetzer@startmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
